Author Topic: CUB BEAR 175 AMPLIFIER  (Read 3395 times)
K1CET
« on: October 04, 2002, 10:25:33 PM »
Hi, Everyone.
I recently aqquired used brick amplifier with only
CUBBEAR 175 in front of the unit. I am sure it is a category of VHF/UHF amp with maybe 175 watts.
Does anyone know who the really manufacture of this amp and what vhf or uhf band this is for?
(i.e 2m, 6m, or 70cm) I would really be appreciated for the information.
73, Adam
« Reply #1 on: October 05, 2002, 09:22:54 AM »
I've been wrong a lot of times in my life, and maybe I am now. But if memory serves correctly, this is a CB amp and not suitable for amateur use.
Alan, KØBG
W5RB
« Reply #2 on: October 05, 2002, 08:44:32 PM »
A Google search shows the site  below has schematics for something called a "Cub Bear 200 " amplifier .I'd wager it's something similar , and thus , likely for CB .
( http://www.cbrepairs.com/schematics/sched2.asp )
N6AJR
« Reply #3 on: November 14, 2002, 03:37:01 PM »
lets call this a 10 meter only amp..hi hi
WA4PTZ
« Reply #4 on: November 24, 2002, 07:48:23 AM »
The Cub Bear 175 is a wide-band RF amp designed to
operate at its best efficiency between 25 mhz and 30
mhz . Output at maximum is 150 watts. It will work on
all HF bands and 6 meters but it is kinda trashy on
the harmonics. A low-pass filter helps but it will
still trash up HF. I believe that if a fellow were
to build a proper filter input/output network and
make proper pi-networks for this amp it would be a
great little amp to enhance a low power rig.
73 - Tim
