Author Topic: PROBLEM TO SUPPORT HYGAIN AV640 ITSELF , BY CLAMP  (Read 1352 times)
SV1CEL
« on: July 11, 2003, 08:43:00 AM »
ACCORDING TO AV640 MANUAL AT THE DISTANCE OF ABOUT 14 FEET FROM THE BASE I CAN ATTACH (HOW ??) DACRON ROPE GUY TO ENHANCE THE ANTENNA SUPPORT.
THE QUESTIONS ARE:
1)WHAT MATERIAL I  CAN USE (NON CONDUCTIVE) SO THAT TO SECURELY+PERMANENTLY FASTEN THE DACRON ROPE GUY ON THE ANTENNA ITSELF.
IF YOU HAVE ANY  BRAND NAME RECOMMENDED IT IS WELCOME
2) ARE THERE WORKING SOLUTIONS THAT (AGAINST THE  HYGAIN RECOMMENDATIONS) USE CONDUCTIVE CLAMPS. PLEASE GIVE ME DETAILS AND POSSIBLE IMPLICATIONS TO ANTENNA TUNING+BEHAVIOUR
« Reply #1 on: July 11, 2003, 02:36:35 PM »
Of course you can use conductive clamps; they don't change the resonance of the antenna in any way at all.  The only important thing is to use non-conductive guys (ropes) and not wires.
I've guyed many AV640's using ordinary conductive clamps and braided Dacron rope, and they worked exactly the same, including resonant frequency points, with or without the guys -- although when the guys get wet during a rainstorm, that will shift resonance a little bit.  (It returns to normal when the ropes dry.)
WB2WIK/6
