Author Topic: uniden 245xlt scanner info needed  (Read 299 times)
AA9JE
« on: January 01, 2004, 01:59:37 AM »
I am in need of some help on a possible problem with my uniden 245xlt trunk tracking scanner. I have had this scanner for years now. When you leave the scanner turned off for a while and then turn it back on the scanner is in the trunk tracking search mode instead of the id list scan mode. Does anyone know how to correct this problem? Does the scanner need repaired? I have reset the cpu and reprogrammed this unit many times but this did not fix the problem. Can anyone help in this problem?
N3ZKP
« Reply #1 on: January 01, 2004, 11:51:24 AM »
Is there an internal backup battery?
If so, have you replaced it? It could well have given up the ghost.
Lon
