Author Topic: Yaesu VX-5RS  (Read 1711 times)
KD5DQQ
« on: June 14, 2004, 04:27:58 PM »
I recently bought a used VX-5RS, and I am having problems reaching a local repeater. I know that the radio is transmitting. I am not sure about the antenna that is on it. It shows in the manual the two top pieces and I only have one I am not sure if I have the right one that I need to transmit on 2 meters.
W7DJM
« Reply #1 on: June 15, 2004, 11:11:14 AM »
When you are troubleshooting, like this, you must assume NOTHING and check EVERYTHING.
The factory antenn has two possible pieces.  A short piece, about 1 inch long, is used on 2m and 440 mhz.
A longer piece, about 3 inches long, loads the antenna for 6 m.
I doubt that the short piece would make much difference on 2 or 440
First, does the local repeater use carrier squelch, or "pl tone"  (CTCSS)?  If so, are you sure you have the "tone" set correctly?
I would get this thing to a competent "friend" who can check
Power output into a dummy load
Make sure the radio is transmitting "on frequency."
Make sure that the "PL" tone (CTCSS) is "on frequency" and within deviation limits.
See if a friend, with a similar power HT, can "get into" the troubled repeater at the same location you are trying to use.
I have no idea what type of locale you live in, you might even try to befriend a ham that may work at the local "two way" shop.
