Author Topic: Yaesu FT747GX w/ Rig Control Software  (Read 1348 times)
AB7JK
« on: April 19, 2005, 10:03:42 PM »
Has anyone been able to get an FT747GX to work using it's CAT connector with radio control software. I've tried several programs all with same results - radio does not acknowlege commands, then freezes with the radio in FM Narrow mode. Could be a bum chip in radio. Any help from someone experience with this problem is appreciated. Kim AB7JK
F6DEX
« Reply #1 on: May 01, 2005, 11:21:51 AM »
These old Yaesus are sometime erratic and their buffer does not process successive bytes properly. One possible solution is to send byte by byte with a slight delay between each byte. But result is not guaranteed. 73, Laurent
