Author Topic: Hole for SO-239  (Read 1359 times)
WA5UHK
« on: March 27, 2006, 05:40:15 PM »
What's the best way to cut a clearance hole through ~1/8" cast aluminum for a SO-239 chassis connector?
OBSERVER11
« Reply #1 on: March 27, 2006, 07:00:49 PM »
I use a stepped bit. Buy it from Harbor Freight, Home Depot charges WAY TOO MUCH!
HA5RXZ
« Reply #2 on: March 28, 2006, 08:44:18 AM »
1) Small hole and a variable width reamer.
2) A series of small holes and a round file.
3) A series of small holes and a Dremmel.
or
4) A single pilot hole and then a 16mm bit to finish the job off. 16mm is about 20/32 of an inch, that's the price you pay for not going metric.
HA5RXZ
« Reply #3 on: March 29, 2006, 01:10:31 AM »
Rather than look for a 16mm drill (which might be harder to find in the US), you can use a 5/8 inch drill bit with a pilot hole. Go very slow, and use a drill press. If your drill press doesn't go above 1/2inch, use what is sometimes called a 'blacksmith's drill', which has a turned down shank to fit a smaller drill chuck. Drill shanks are normally relatively soft, and can be turned down fairly easily.
You might even get away with a Greenlee punch (5/8 inch for miniature 7 pin tube socket)
Some varieties of nut fixed (as opposed to flange fixed) SO239 sockets have a smaller size thread - from memory, something like 1/2 inch diameter - for fixing.
HA5RXZ
« Reply #4 on: March 29, 2006, 09:38:45 AM »
Sorry, you're right, 16mm is 5/8ths of an inch. I measured a socket before I posted but used a metric gauge. Back to math classes for me.
HA5RXZ
« Reply #5 on: March 29, 2006, 12:31:16 PM »
Actually 5/8 = 20/32, so your answer was correct.
The difference just points out one of the ways that Metric
measurements are easier to use.  It is a lot easier for me
to sort my Metric sockets in size order than the Imperial
sizes:  1/2, 9/16, 5/8, 11/16, 3/4, ...
