Author Topic: Replacement for ICOM 746Pro?  (Read 947 times)
KB3OAH
« on: April 09, 2007, 06:51:37 AM »
I am about to purchase a new HF rig and have narrowed the choices down to the ICOM 746Pro. The 746Pro is a little long in the tooth and I suspect that there may be an improved 746Pro in the wings. Any suggestions and insight would be appreciated.
Dan
AB3EN
KB9YUR
« Reply #1 on: April 10, 2007, 03:21:35 AM »
Dan,
you didn't say if you would consider a used radio.
I've owed the 746 (non-Pro) for 6 years now with no
problems at all. But, I would also consider other
radios from the past as well.
KB3OAH
« Reply #2 on: April 10, 2007, 03:40:26 AM »
I would consider other and older rigs. Currently I have a TenTec Delta That will most likely become a mobile. I like the DSP of the Icom 746Pro and I am currently working with some SDR projects such as the Softrock v6 TxRx module.
If I spend the bucks I figured to buy something that is the best bang for the money. Suggestions welcome.
Dan
AB3EN
N5EAT
« Reply #3 on: April 26, 2007, 06:07:55 PM »
A good used Icom IC-775 DSP would be an upgrade without having to buy a 7800.  I have a Yaesu FT-2000 that is the best rig i've owned.
The 746 is a very good rig.  Finding a truly better rig could be a challenge.  The PRO-III is better, but not much.  The Omni 7 and Orion II are better.  The FT-2000 is better..  But by a factor of what I don't know.  Sunspot peak is a while off.  It's tough to tell in the sparse signal environment we have now.
N6AJR
« Reply #4 on: May 13, 2007, 10:31:32 PM »
I have a 746 pro, a ts2000, a pegasus, and an Orion, ( and a ft 847 and 6 or 7 more)and I use the Orion most and the Peg second, the 746 pro is my station for visiting hams. it has a at 500 and a 2-kl.  the orion is a better contester, but the 746 pro ain't bad. ( I also had a 756 and it was pretty good too.
go with the orion, or the orion II or keep the 756 pro and put $3000 or so into a tower and a nice 3 or 4 element steppir..
http://hometown.aol.com/catfishtwo/N6AJR.html
 pic of the shack
