Author Topic: FT 8900  (Read 1847 times)
K5WQH
« on: June 18, 2008, 06:50:02 PM »
When this radio is not in crossband repeat mode it will transmit by itself. The transmission lasts about a half second.
Has anyone else noticed this?
N4CQR
« Reply #1 on: June 19, 2008, 09:01:35 AM »
No such problem here... FT-8900r about 14 months old.
W3LK
« Reply #2 on: June 19, 2008, 10:40:52 AM »
Yeasu used to have a function in their HTs and mobiles called Auto Range  System.
If you had DCS operation selected and ARTS turned on, the radio will transmit a 1-second DCS burst to see if any other radio with DCS and ARTS turned on was in range. It would do this every time the PTT was pressed or bout every 15 seconds. If another radio was in range, it responded and your radio would ring bell.
Perhaps you have this turned on.
Check your owners manual for the ARTS system.
Lon - W3LK
Naugatuck, Connecticut
W3LK
« Reply #3 on: June 19, 2008, 10:41:53 AM »
Make that Auto Range Transpond System.
Lon - W3LK
KB1OCC
« Reply #4 on: June 19, 2008, 11:10:20 AM »
FYI - Yeasu still uses it ("ARTs")
K5WQH
« Reply #5 on: June 19, 2008, 06:18:17 PM »
I guess this should teach me to read the manual. I do appreciate everyone's help.
73'
Marty
W3LK
« Reply #6 on: June 19, 2008, 07:21:27 PM »
Was having ARTS turned on the problem?
Lon - W3LK
K5WQH
« Reply #7 on: June 22, 2008, 04:41:29 AM »
Does not appear to be the problem.
This particular radio has manafested some other problems as well. The cure has been to turn it off and back on.
Once it had very low audio on xmit. Turned it off and back on and the problem was cured. Same thing on this momentary xmit problem.
Thanks for the help.
Marty
W3LK
« Reply #8 on: June 22, 2008, 11:37:11 AM »
I think it's time to send it to Yaesu.
Lon - W3LK
W3LK
« Reply #9 on: June 22, 2008, 02:33:15 PM »
BTW, have you done a RESET, according to the manual?
Sometimes a reset will solve a multitude of problems.
Also, has it been modified for out of band operation? That can also, if not properly done, cause strange things to happen.
Lon - W3LK
K5WQH
« Reply #10 on: June 22, 2008, 03:07:46 PM »
Not yet. But I am going to do that next.
There have not been any mods made.
Marty
