Author Topic: how many items can a power supply run?  (Read 308 times)
AI4WX
« on: February 17, 2009, 01:38:16 PM »
i have a radio shack PS that puts out 25A. What i would like to know is if i can hook up both my yaesu and a KDK rig to try and diagnose a problem at the same time. I tuned the KDK according to the owners manual, but its still 5 hz off freq. i thought maybe by having another rig running i can make sure that it fixed the problem.
« Reply #1 on: February 17, 2009, 01:56:49 PM »
You can connect whatever you want as long as the total load doesn't exceed 25A.
5 Hz off?  Most rigs can't even resolve 5 Hz, let alone be that close.
Do you mean 5 kHz?
AI4WX
« Reply #2 on: February 17, 2009, 04:47:20 PM »
maybe..  i am basing this off what other ppl say they pick me up at.. but i'm gonan try and figure out why this thing is off.
K7KBN
« Reply #3 on: February 17, 2009, 07:31:23 PM »
Wha'd we ever do without digital displays?
(Answer):  We'd get on the air, be aware of the band edge, and have fun.  Of course, that was back before "Hertz" was invented.
FIVE cycles per second?  Is that high or low?
Pat K7KBN
CWO4 USNR Ret.
AI4WX
« Reply #4 on: February 17, 2009, 08:47:22 PM »
its 5 too high. so like 1 of our freq's is 147.195, ppl say i end up transmitting on  147.200
« Reply #5 on: February 18, 2009, 03:47:24 PM »
Then the difference is 5KHz, not 5Hz.
W0FM
« Reply #6 on: February 19, 2009, 11:23:46 AM »
Minor clarification.
Your power supply doesn't "put out" 25Amps, it has a *capacity* to *provide* 25A.
Amplifiers and transmitters, etc "put out" (Insert inappropriate thought here).
You "draw" current from a power supply.
Good luck.
Terry, WØFM
KE3WD
« Reply #7 on: February 22, 2009, 09:11:50 PM »
Listen to Terry and take heed.
N2UGB
« Reply #8 on: February 25, 2009, 01:58:38 AM »
I have a 7 amp Ten Tec power supply. Originally for an Argonaut 20-watter. Sold the Argonaut but kept the PS. Now use it for my FT-817 (5-watts) and Timewave filter. More than adequate.
Like the early contributer commented, depends on what you are putting into it and their requirements.
