Author Topic: RF Signal Generator  (Read 1103 times)
KG6GZM
« on: April 21, 2009, 02:00:28 AM »
I’ve purchased a used Pager RF Signal Generator. The generator was exclusively built to LeeTEL Communication by Sandstone Research Sciences. The previous owner claimed that the generator’s frequency range is from 150MHZ to 1GHZ. However, the generator’s current default starting frequency is 500MHZ; and it won’t generate a correct frequency when the frequency is below 500MHZ. At current situation, I can only generate 500-1000MHZ useable signals. I don’t believe the owner lied to me because he’s been sincere to help me with the issue, but whatever I do it won’t work below 500MHZ. I can key in almost all frequencies and signal generating sign would blink when transmitting the frequency, but it’s not a viable signal or no signal at all. I even tried with different amplitudes, but it wouldn’t work.
4U rack mount case
Model #: Super Tech 2000
LCD Display with all keypad input
Separate pager testing Function keys
1.5 VDC power out
Manufacture: Sandstone Research Sciences (for LeeTEL Communication)
I’d appreciate any help at all. Thanks
