Author Topic: going mobile in a Toyota 2001 Camry  (Read 345 times)
KA3JJZ
« on: May 28, 2001, 03:32:28 PM »
  Well I guess the topic says it all.  I want to get my FT8100 into the Camry-
I do have the remote mounting kit, but I'm not sure where to put it.  There
are speakers in the back at the top near the trunk, so I can't put the radio
there (too much chance of inadvertant RF pickup), and I'm having a heckuva
time with finding spots for the speakers.  Anyone?
  I am also interested in anyone doing HF mobile from the Camry.  I'm
thinking of putting a FT817 QRP rig in there, and of course, I'm looking for
any hints for *real* grounds (as in where to find them!) and antennas and
such.  Any hints would be appreciated.
  73s and thanx  Mike  ka3jjz@erols.com
W0LMD
« Reply #1 on: June 11, 2001, 04:33:40 PM »
I have put a mobile rig in my '97 Camry recently.  The rig is a Kenwood TS-2000 which is placed under the passenger seat from the rear.  The remote head is placed in the slot area between the AM/FM/Cassette radio and the heater/AC controls. The microphone is on a long cable, and the small Kenwood speaker is placed in the Camry's cup holder when used.
The antennas consist of a spring loaded mount on the right rear fender holding a Hustler HF antenna set. A 5/8 2M antenna is attached to the trunk lid on the forward left.  A 5/8 magnetic mount 440 Mhz whip is placed on the roof. The coax lines are routed from the trunk area under the floor mats and inside the bottom car frame passenger door molding and exit next to the right side of the passenger seat.
Power to the rig is supplied by  red & black #10 leads from Radio Shack.  These fused leads are routed from the battery on the front left of the car, across and slightly in front of the top of the radiator area, then back towards the passenger door.  There is a slight gap between the top fender holding bolt and the frame through which I route the wires, then downward inside the passenger door well at the front until it is pushed into the bottom car frame passenger door frame molding for a few feet until it exits with the other cables.
I have bonded the exhaust pipe, the trunk lid, the hood lid, the engine in multiple spots, and the airconditioner lines to the car frame. The ignition noise still runs aout S5 which masks out the very waek signals.
The mobile system is only used on long trips when the wife is driving, and I work SSTV and PSK-31 with headphones and a laptop computer plugged into a 117 vac inverter powered from the car's 12v system.
I have pictures of the installation if interested.
Robert   W0LMD         W0LMD@yahoo.com
KA3JJZ
« Reply #2 on: June 17, 2001, 08:56:48 PM »
  Hmm,. I've been doing some reading, and found that Toyotas in general
sometimes have problems in the fuel pump with them radiating noise
(no, I'm not sure how!).  Also have you bonded the car doors- your message
didn't say.  And it also might be time for an alternator noise filter; the
message didn't say what kind of noise you were experiencing...
 73s and thanx  Mike
