« Reply #2 on: August 27, 2001, 06:04:05 PM » |
I think the K40 is a CB antenna, a base-loaded whip. If so, I doubt it could work on 6m at all, cut to any length, because there's too much inductance in the base coil...you might have to cut the whip all the way down to nothing!
Without knowing exactly HOW much inductance is in that base loading coil, it's impossible to predict what, if any, whip length would resonate the antenna on 6m. If you don't mind sacrificing the antenna, anyway, you might try an Antenna Analyzer like the MFJ-259...and start cutting the whip down, to see how many MHz per inch you get. That is to say, if you cut an inch off the whip and its resonant frequency changes from 27 MHz to 29 MHz, that's 2 MHz per inch. At 2 MHz/in, you'd need to cut 12.5" off the whip to tune it down to 52 MHz. Something like that...you'll find out, if you start doing it!
73 de Steve WB2WIK/6
