Author Topic: Moble Radio  (Read 1236 times)
KB9VVT
« on: January 27, 2002, 06:57:42 PM »
What access through the firewall on a 2000 Jeep Cherokee should I use for power connection and antenna coax?
WPQX931
« Reply #1 on: January 28, 2002, 11:18:42 AM »
I don't think they still have the Clutch Cable hole in the 2000 Jeep anymore, so use the Powersteerling boot as your pass through in the firewall.   But if you do have the clutch cable block-off plate, use that by drilling a hole in it and do it thatway.
BTW, whey are you putting coax through the firewall?  are you mounting an antennal on you hood?
Alex
KB3HLP
