Author Topic: Can Yaesu VX-5R be used with 13.8volts?  (Read 1743 times)
VK3
« on: December 08, 2001, 02:00:02 AM »
Can the vx-5r be operated from a 13.8volt source without incurring damage to the HT?  Have heard that the radio heats up during TX and causes damage.  Is this a design fault?  I would aprreciate any suggestions from owners of the unit.  73's Dan
KC8AXJ
« Reply #1 on: December 08, 2001, 05:08:52 PM »
According to Yaesu's spec.s:
 http://www.yaesu.com/amateur/vx5rtx.html
Supply Voltage: Nominal:  7.2 V DC, Negative Ground
Operating:  4-9 V DC (Internal Battery)
10-16 V DC, Negative Ground  (EXT DC jack)
Handhelds, because of a lot of power options i.e. car battery, attached batteries of verious voltage, are desined to work without a "set" voltage. The only trade off is power out. Less power in.......less out.
I have a Icom T22 Which will put out 5 watts from a external sorce (13.8V) or it's 7.2V ni-cad.
If I do a lot of transmitting, it does get quite warm.
(Nice in the winter, Hi Hi)
The body of these things aren't that big as far as being a "heat sink". My mobile will even ge a LITTLE warm at 5 w out and that is quite a lot more iron than a handheld.
I wouldn't worrie about it too much, just try not to key up for long periods, even 15-20 seconds at a time can add up heat wise.
These things aren't really a good rag chewing device unless you can run on the low power setting.
Hope that helps!
Steve   kc8axj@arrl.net
KC0IWV
« Reply #2 on: January 28, 2002, 06:23:45 PM »
According to Yaesu you should be able to use a 13V source for this HT.  I own one myself and have used it in the car off of the battery.  It does dissipate a lot more heat.  I asked the technician at Yaesu about this and he said it is designed to handle 12V+ but will need to dissipate a lot more heat.
I personally don't use mine this way - the unit gets hot enough with 7.2V input that I'm suspect that 13 Volts might not be the best thing for the rig.
However, I know a lot of Hams who do run them off the car battery and have had no problems.
So the answer to your question is yes.
