Author Topic: problem with FT 100 d  (Read 1436 times)
F0DQZ
« on: June 03, 2002, 02:28:56 PM »
Hi,
i have a little problem with this tranceiver,
with a battery, i can't transmitting, they have a
Hf problem, ROS,
but i have less problem with power supply,
you have a idea ?
thanks
sebastien
« Reply #1 on: June 03, 2002, 05:45:31 PM »
Without more information, this one is a little hard to diagnose.
The FT100D draws about 20 amps maximum at a nominal 13.6 volts DC. I don't know what sort of battery you are using, but you need to make sure the battery and wiring will handle the 20 amp load.
I get the impression you are running the rig mobile. If you are, and the SWR is too high (>3:1), the radio will shut down its finals. The SWR needs to be under 2.5:1 and preferably lower. Instead of using the antenna, connect the rig to a dummy load and see if it transmits. If it does, the problem is not the radio.
If you can provide additional information, maybe I or one of the other hams can give you a better idea of the problem.
Alan Applegate, KØBG
