Author Topic: Tips for Cleaning NMO Mounts  (Read 224 times)
KG4EBZ
« on: March 04, 2003, 11:04:03 PM »
Hello All
Quick question.  Anyone have any experience/tips for cleaning the contacts on NMO mounts?  I have some corrosion that is the likely source of higher than normal SWR.
THANKS
« Reply #1 on: March 05, 2003, 09:25:20 AM »
A small wire brush is your best bet. The insulating material is rugged enough to withstand moderate brushing.
Don't forget the antenna contact.
Alan, KØBG
« Reply #2 on: March 05, 2003, 10:01:04 AM »
Careful not to grind through the silver plate on the center contact, if it's got it.  Sometimes this ends up black if the antenna gasket has failed, just polish it up with a dry rag.  If it's all rusty, whatever plating it had is gone and might merit replacement of the mount.
k5lxp@arrl.net
