Author Topic: Taurus wagon Coax exit  (Read 194 times)
WA2HMM
« on: March 11, 2003, 09:01:12 PM »
I have a 1991 Taurus Station Wagon, need to get coax out to mag-mount, any Ideas??? would rather not use Glass mount, nor drill hole in roof.
KE4DRN
« Reply #1 on: March 12, 2003, 12:26:05 AM »
Hi,
I also have the taurus wagon.
For a while I ran the coax out the right rear
door along the rubber seals.  I attached
those stick on squares that you pass a cable tie
into to keep the coax snug to the area where the
door hinges are.  The cable fits nice between the
door gap and runs to the magmount.
I used the removable cable ties so I can remove
the magmount if necessary.
Another option is to run the coax out the back
where the spare tire is stored. There are rubber plugs
at the bottom corners of this space.
73 james
