Author Topic: Antenna Tuner  (Read 1246 times)
KB1HBS
« on: April 28, 2003, 12:25:41 AM »
I own the ICOM-706MK2G and I am thinking about hooking up an HF/6M antenna to the unit. Currently this radio is for Mobile use. Which automatic antenna tuner would be the best buy? AT-180, or AH-4.
Also what is the Pros & Cons with each of these??
Thanks and 73’s
N8EMR
« Reply #1 on: April 28, 2003, 07:54:02 AM »
What antenna would you be using. Th AH-4 is designed to feed long wire and whips. The at-180 is designed to feed balanced antenna's. Both are good but for different antennas.
« Reply #2 on: April 28, 2003, 09:15:02 AM »
The correct unit is the AH-4.
I have several articles published here on eham.net specifically covering the AH-4 in mobile operation.
http://www.eham.net/articles/4407
http://www.eham.net/articles/4424
http://www.eham.net/articles/4425
http://www.eham.net/articles/4623
Alan, KØBG
