Author Topic: Thru-glass Antenna Whistle  (Read 1275 times)
VE1HUP
« on: October 23, 2003, 12:34:11 PM »
Hi,
Has anyone else encountered their thru-glass dual band antenna whistling at highway speeds?  It is very annoying.  I believe the noise is originating from the coiled part of the antenna.  Just wondering if anyone has come up with a "tidy" solution to the problem?  I was thinking about trying some heat shrink around the coil to see if that would quiet things down.
Any suggestions out there?
Many thanks.
73, Darryl
VE1HUP
KG8S
« Reply #1 on: October 23, 2003, 01:05:17 PM »
I just folded up the shrink wrap and stuck it down into the coil...whistle gone.  All you're trying to do is to disrupt the airflow around the coil.
W4EA
« Reply #2 on: October 23, 2003, 03:34:50 PM »
I took shrink tubing, put it over the coil and applied heat, did the trick.
W4DMM
« Reply #3 on: January 03, 2004, 05:21:46 AM »
I used the heat shrink route also. Have heard of people using the foam ear plugs also.
Mark
