Author Topic: Newbie help.  (Read 1022 times)
KG4ZIO
« on: February 13, 2004, 12:20:50 PM »
This is so stupid but I just bought my first mobile radio and was wondering what everyone uses to connect the power cables to the battery.
« Reply #1 on: February 13, 2004, 12:25:37 PM »
I use crimp-on ring terminals of sufficient internal diameter to attach directly to the battery terminal clamps (using the bolts that are already there, and part of the clamps).
Don't forget your fuse or fuses should be in the DC cable *right next to* the battery terminals, not by the radio!  You want to be sure that any accidental short circuit in that cable, anywhere, will blow the fuse(s) and not burn the wire insulation.
WB2WIK/6
