Author Topic: INFO ON THESE ANTENNAS!!!!!  (Read 1054 times)
VE7REN
« on: February 14, 2004, 01:41:27 AM »
HAS ANYONE HAD GOOD LUCK WITH THE VALOR 002 MAGMOUNT MOBILE,OR THE WILSON 5/8 2 METER ANTENNAS.IM TOSSING TO GET EITHER ONE.THE WILSON LOOKS BETTER CONSRTUCTION.I WANT TO STAY FAIRLY CHEAP ON PRICE,BUT I DONT KNOW WHAT ELSE TO GET??? I WANT MAG,AS SHORT A WHIP AS POSSIBLE,100WATT CAPABILITY.
« Reply #1 on: February 14, 2004, 10:43:51 AM »
In the future please do not use all caps as they are hard to read and are the web equivilent of shouting.
The shortest possible 2 m mobile antenna is a 1/4 wave. The difference between it and anyone's 5/8 wave in an urban setting is moot. You do add a measure of loss using a mag mount so permanent mounting is preferred. An NMO mount is the best solution.
Alan, KØBG
KC8AXJ
« Reply #2 on: February 14, 2004, 11:25:42 AM »
Larson 5/8 wave, NMO mag. mount.
Bar none !!
If your use is  "urban" ( a never leaves the (big ?) city kinda person), then yes, 1/4 W would be fine. But who doesn't get out and about now and then.
Or, get both elements and change it to your environment.
IMHO
Steve
« Reply #3 on: February 14, 2004, 05:28:43 PM »
One thing to keep in mind Steve, a 5/8 wave has a slight advantage in gain, which lowers its radiation angle. Depending on the HAAT of the repeater antenna, this may be a disadvantage, urban or suburban use notwithstanding.
If you check in Radiall/Larsen's catalog and read the fine print, you'll see that a roof mounted 1/4 wave will typically out perform a trunk mounted 5/8 wave.
Alan, KØBG
