Author Topic: Small Ship Antenna  (Read 1630 times)
VE7JJD
« on: June 01, 2004, 02:01:40 PM »
I am building a small, Square Rig (Hermaphrodite Brigantine), two masted, Sailing Ship: and am putting a HF transceiever aboard (Icom HF-730).
I am in the final throes of antenna selection. The masts are fiberglass, twelve feet long, and the hull (a San Francisco Bay Pelican), is wood and also 12' long.
For convenience I am looking at an inverted L up one mast and accross to the other and a smart auto tuner.
I am also looking at a good quality Screwdriver antenna 80-10 meters.
My question is will one "get out" significantly better than the other?
A second question is there something significantly
better?
The ground plane will be interconnected wire mesh mats covering the inner surface of the hull. Approximately 11'L x 5'W = 55 square feet.
« Reply #1 on: June 01, 2004, 04:46:40 PM »
The physically larger inverted-L should perform much better than the screwdriver, especially on the lower frequencies.
« Reply #2 on: June 01, 2004, 06:17:16 PM »
If you use an auto-coupler to match the antenna, remember to ground the other side of the coupler to the keel plate.
Alan, KØBG
www.k0bg.com
