Author Topic: UHF/VHF Duplexer Worth the Effort?  (Read 1032 times)
WD6AGJ
« on: July 07, 2004, 12:13:42 AM »
Hi All,
Is it worth using a duplexer with individual antennas for 2m/70cm versus a good dual band antenna?  73, JC
K7VO
« Reply #1 on: July 07, 2004, 12:25:40 AM »
IMHO, no.  A good dual band antenna can do as well as a single band antenna.  In fact, a good triband antenna (mine covers 2m, 222, and 440) can also work brilliantly.
Caity
K7VO
« Reply #2 on: July 07, 2004, 10:20:12 AM »
A diplexer often costs more than a dual band antenna, plus you still need to buy two antennas, and run two coax lines.  No clear advantage to doing it unless you have a specific purpose in mind.
OBSERVER11
« Reply #3 on: July 16, 2004, 04:59:23 PM »
depends on what you need.
Sometimes, a dual band antenna just will not work as well as two (or more) 1/4wave antennas. If you live in the mountains, a 1/4 is better than a 5/8 wave. If you are a flatlander, a 5/8wave is better than a 1/4wave.
If you need to run an amp, then you may want to run monoband antennas.
If you do not have the space on the car, then a dualband is a good compromise.
