Author Topic: Best mag mount antenna ?  (Read 753 times)
XYZ234
« on: November 07, 2004, 08:27:03 PM »
I'm just getting into ham radio (still studying for test)and am interested in getting a 2 meter mobile rig for the car.
I want to start out with the highest quality antenna right from the start (instead of starting with a cheap used one and working my way up from there like I did when I was CB'ing).
What antenna can you guys/girls suggest ?
I know Wilson puts out one of the best CB antennas but what about the Wilson 2 meter antenna ?
Thanks.
K0BG
« Reply #1 on: November 08, 2004, 05:15:14 AM »
There is no BEST mag mount. In fact, they are dangerous in the event of a crash. This past February a bystander was struck and killed by a mag mount antenna which dislodged due to a crash.
I'm not too sure Wilson makes the best CB antenna because their literature exaggerate the facts. One of the most popular VHF/UHF amateur antennas is the dual band Larsen NMO270.
If you're looking for a monobander, a standard old quarter wave is hard to beat in an urban setting.
Roof mounting is preferred, with the middle of the trunk is second best.
Alan, KØBG
www.k0bg.com
N2MPT
« Reply #2 on: November 08, 2004, 07:25:17 AM »
diamond.
comet.
larsen.
any of the above on a proper thru-hole NMO mount.
mag mounts suck due to poor grounding, can fall off, usually cause gasket leaks, and will scratch up the paint.  there's not a lot going for mag mounts.
jim / n2mpt
« Reply #3 on: November 08, 2004, 09:42:37 AM »
Alan, can you point me to documentation of this. I could use it to make a case for a work related issue.
KB9KHF
« Reply #4 on: November 08, 2004, 02:58:25 PM »
I use a Wilson 2m mag mount on my Jeep.  I like it, the mag holds very well on the hiway, and it certainly is a much better antenna, than a cheapo model I bought off Greed-bay.
That being said I am getting a permanent mounted antenna, as I am tired of the magnet mount flying off, on the trail.
K0BG
« Reply #5 on: November 09, 2004, 06:30:29 AM »
Bob, I'd have to go searching for it again, but here's the site:
http://www.nhtsa.gov/people/crash/Index.html
Alan, KØBG
www.k0bg.com
K5CUR
« Reply #6 on: November 15, 2004, 09:15:03 AM »
I couldn't use a mag mount if I wanted to.  It's a mustang convertible with trunk and hood made of fiberglass.  Magnet no stickee.
The only place I can put a mag mount is on the fender next to the trunk.  I tried that for a little while, but the fender is slightly rounded, so the magnet did not have a completely flat surface and held even less firmly than usual.  It didn't fall off, but it had a tendency to walk off the fender and would have fallen off in a short time if I hadn't moved it back several times.
I still didn't want to drill visible holes, so I got a lip mount.  It is screwed in place, but the screws are on the inside, out of sight.
