Author Topic: tm 700 daul bander with 2 antennas  (Read 187 times)
VE9EMT
« on: April 30, 2005, 08:21:35 PM »
I need to know what I need to alow me to take the single output of my dual band radio and alow me to have a seperate antennas for the 2m band and 70cm band. is is a diplexer?Huh I also use my radio for outside ofthe band plan does it make a difference?Huh
« Reply #1 on: May 01, 2005, 06:44:39 AM »
The diplexor is what you need. However, you'd probably be better off with a Larsen NMO2/70 or similar dual band antenna.
When you say "out of the band" do you mean to listen or transmit? Transmitting out of band with an amateur transceiver is verboten.
Alan, KØBG
www.k0bg.com
KC0MDC
« Reply #2 on: May 02, 2005, 09:29:07 AM »
I agree with Alan here.  I've got a Larsen dual-band antenna and it works just fine with the D-700.  I'm also able to RECEIVE non-ham bands pretty well with the antenna when scanning through other frequencies.
73 de Tim
N3ZKP
« Reply #3 on: May 02, 2005, 01:44:05 PM »
Let me add my opinion, as well.
Forget the separate antennas, they are not necessary. Get the Larsen and you'll have all you need without all the fuss and bother.
Lon
