Author Topic: what size screw  (Read 3128 times)
KB2MS
« on: June 30, 2005, 04:52:43 AM »
lost the screw that grounds the 0pc 581 to the icom 706.  this acts as a ground so no rf gets into the radio. please help
« Reply #1 on: June 30, 2005, 05:29:35 AM »
Good luck, they are hard to find. It is a 2mm screw, and most Ace Hardware stores carry it. Be careful, as it is just 3mm long. Any longer and you run the chance of touching the circuit board inside. If you can find one, use a pan head screw. If not, a round head and a very small lock washer will work.
You're correct about the screw grounding the cable. Lots of folks miss the screw , loose it, or just don't install it and end up with all sorts of RFI problems. The major one is shutting down if the power is over a certain level.
Alan, K0BG
www.k0bg.com
« Reply #2 on: June 30, 2005, 06:15:23 AM »
What you're looking for is an 'M3', phillips panhead screw, 3mm long.  I've discovered that most consumer electronics gear is held together with metric screws and have found a host of M3 (and other sized) hardware by salvaging dead PC monitors, power supplies, VCR's, etc.
KL7IPV
« Reply #3 on: June 30, 2005, 09:25:19 PM »
Check at Lowe's as well. I have found some odd sized screws there, even the ones I needed for the Icom to mount on the mobile mount (7mm).
Frank
KL7IPV
KB2MS
« Reply #4 on: July 01, 2005, 06:25:56 PM »
Alan tnx I replaced the screw, and no more rf shut down.  73 mark kb2ms
K2MFW
« Reply #5 on: May 07, 2012, 01:20:44 PM »
Look at the hard plastic feet in the front of the rig, that holds the tilt bar. There are 4 screws that hold these 2 feet to the rig. Remove one and use it for the seperation cable screw to ground the cable properly to the 706 chassis. You don't need the screw for the feet, missing one is perfectly fine. It's a perfect fit for the hard to find screw that everyone's talking about here.
W9PMZ
« Reply #6 on: May 07, 2012, 10:08:43 PM »
look in the junk computer for this screw...
KI4SDY
« Reply #7 on: May 08, 2012, 01:10:32 AM »
A local Fastenal industrial shop can get any screw, if Ace Hardware does not have it.  Wink
KC3L
« Reply #8 on: May 08, 2012, 10:23:24 PM »
I think Home Depot might carry it length might be a problem.
Lee KC3L
