Author Topic: Ball mount on a 95 ext cab Chevy,can it be done?  (Read 194 times)
KG8Q
« on: July 11, 2005, 07:41:14 PM »
I have a 1995 Chevy Silverado extended cab and I'm wondering if anyone has mounted a ball directly behind
the little extended cab window up high . I started to remove the interior panel but it was such a pain plus the seat belt assembly looked to be in the way so I didn't pursue it . I have the version where there is no "door" on the extended portion of the cab nor is it a 4 door crew cab . It's just a plain ole extended cab.
Thanks
N2HBX
« Reply #1 on: July 28, 2005, 05:39:29 AM »
Hello,
The local Water Management District that I used to do radio work for had similar vehicles. They mounted a plate to the front corner of the pickup bed and attached the ball mount to the plate. They were on a 30 Mhz government frequency. The setup worked very well.
Larry, N2HBX
