Author Topic: FT-100D DC Power connector  (Read 536 times)
AE6NG
« on: January 13, 2006, 12:01:23 PM »
Hi,
Does anyone know what type of DC Power connector for Yaesu FT-100D? And where can I get one?
I am trying to mount the rig on my car, and don't want to use the original DC power cable, so I can move the rig easily between home or mobile use.
Thanks!
Johanes
AE6NG
« Reply #1 on: January 13, 2006, 12:43:40 PM »
You're going to find it is cheaper to buy the cable all in one.
The reason is, you have to buy wire, fuse holders, and the plug. I'm sure Yaesu isn't much different than Icom; the parts to duplicate the factory cable is nearly twice the cable's cost.
That said, I build my own, but when I ordered a new plug for my 7000 Icom wanted $12.50 plus shipping, and they didn't have one! I ended up modifying the original as I couldn't even find a replacement cable. So much for buying a new-on-the-market radio.
Alan, KØBG
www.k0bg.com
KC8AXJ
« Reply #2 on: January 13, 2006, 12:45:59 PM »
here ya go:
http://www.gigaparts.com/parts/profile.php?sku=ZCB22001
Steve
KC8AXJ
« Reply #3 on: January 13, 2006, 12:49:54 PM »
OOOPS ! I posted the wrong hyperlink.
This is what I ment, that is if you feel you want to make one up.
http://www.powerwerx.com/category.asp?CtgID=1003
AE6NG
« Reply #4 on: January 13, 2006, 05:55:24 PM »
Steve and Alan,
Thanks for the fast response! I know I can depend on this forum! I will checkout the website. Thanks a lot!
Johanes
AE6NG
KA9ARM
« Reply #5 on: January 14, 2006, 11:08:11 PM »
If you want to roll your own, try:
Look under OEM connectors. You should always have fuses in both sides of the DC line as close to the source as possible.
Andy KA9ARM
WB9QVR
« Reply #6 on: January 17, 2006, 04:42:35 PM »
Johanes, you can also order either the connector or the complete cable assembly from:
http://www.pl-259.com/page4.html
« Reply #7 on: January 24, 2006, 01:53:15 PM »
On all my rigs I cut off the power cable about a foot or
two from the back of the rig and install Anderson PowerPole
connectors on both sides of the cut.  That way I only
need one connector to fit each radio, and all of
my radios and power supplies are interchangable (because
all have PowerPoles.)
Besides, when switching rigs it is much easier to mate
a 2-pin connector on the end of a wire than to try to
reach behind the rig to plug in the multi-pin connector.
