Author Topic: Problem whit VHF installation  (Read 182 times)
LU1HQV
« on: May 02, 2006, 09:25:03 PM »
Hi!
Today I installed my ft 1802 in my truck sonoma 95.
I installed whit a cg-144 hustler and a k400 truck mount.
But my swr still constantly between 1.7/2!!!!
I tried to adjust colinear to 19" but is the same result.
I know I do something wrong but I can't find what is??
Better ground??? I need to ground radio too?? (I can't find any way to ground this radio).
Maybe antenna need other adjustment??
any idea??
Thansk you in advance!
DROLLTROLL
« Reply #1 on: May 03, 2006, 09:58:43 AM »
Check your ground at the PL-259 connector. Make sure the braid has a good ground against the shell, next check that the antenna mount is solidly biting into the vehicle body. Scrape the paint away a little bit to insure good metal to metal contact. Both ends of the coax need to be solidly grounded to maintain a low vswr.
LU1HQV
« Reply #2 on: May 03, 2006, 11:07:11 AM »
Thanks! I'll check righ now!!!
