Author Topic: 12 V antenna rotor  (Read 6070 times)
2ST123
« on: February 13, 2007, 04:51:20 AM »
I was wondering if the make a 12v antenna rotor? I am wanting to get a 2M/70cm mobile later and build some kind of small beam antenna.. Thought it would be neat and would extend my talking distance when i start ham..
                             Roy
« Reply #1 on: February 13, 2007, 05:51:09 AM »
Most people start a ham by putting it into the oven. I believe you mean when you get your amateur license.
While you can certainly build a 2 meter and/or 440 beam, there are so many of them for sale used, you'd save money by buying one used. That said, using a beam mobile in motion can be done, and you'd be far from the first. The problem is, antenna rotor motors are almost always AC, so adapting one is a little difficult.
The last one I saw was adapted from a windshield wiper motor, and worked quite well. The beam was an 11 element 2 meter unit, in horizontal position for SSB work. If you're interested, I suggest www.allelectronics.com. They sell the WW motor, cheap. The rest of it you have to design.
Alan, KØBG
www.k0bg.com
2ST123
« Reply #2 on: February 13, 2007, 06:00:55 AM »
Thanks alot for the info.. I have some BIG copper wire or could use copper pipe and i may have what i need on hand besides the motor.. I knew about
allelectronics.com .. Didn't know they sold the motors though.. Thanks
                      roy
« Reply #3 on: February 13, 2007, 08:26:44 AM »
They used to make some small 12VDC antenna rotors for the RV people.
An easier solution may be to get a small 12VDC to 120VAC inverter to power one of the more popular AC rotors.
KG0SH
« Reply #4 on: February 13, 2007, 10:56:23 PM »
I have a 12V rotator but it is probably WAY more than you need.  See www.alfaradio.ca for the AlfaSpid Rotator.  This is the only rotator I found that did not need some sort of inverter.  I use this to turn a 2 element SteppIR HF beam on my truck.  (Non-moving of course!)
See http://home.comcast.net/~brucet622/wsb/html/view.cgi-home.html-.html and hit the photos button.
Bruce KG0SH
2ST123
« Reply #5 on: February 14, 2007, 05:27:15 AM »
Thanks for shareing your site. I clicked on the photo link and the next page opened up , but no pics.. Thanks for the name of the rotor though , that will be a BIG help... Roy
