Author Topic: Mobile Base Loading vs. Inductive Matching  (Read 880 times)
KB8KRF
« on: July 22, 2007, 09:23:27 AM »
Hello,
I'm attempting to homebrew an HF/VHF/UHF mobile instead of buying one.  I found a halfwave 2m/440 antenna from MFJ for $19 that happens to be 59 1/2" long.  I figured this would be enough to get on HF even if it may not provide stellar performance.  I've read the section in the ARRL Antenna Handbook on mobile antennas several times.  I see how center loading can improve performance over base loading but it doesn't explain how base loading compares to inductive matching alone.
My question is: Does the base loading coil have to be above the ground plane inorder to increase radiation resistance and improve efficiency?  Can't a loading coil placed at the base of the antenna but just inside the vehicle's sheet metal do the same thing?  What if there is 3ft or 4 ft of RG-58 between the base of the antenna and the loading coil?  Will the antenna still perform well?
My preference is to place the loading coil in the trunk along with some switching relays.  This way the coil is in line when Xmitting HF but off line when using the VHF/UHF rig.  Does any one have any experience with a loading coil at this location?
Thanks
John
KB8KRF
