Author Topic: Marine HAM  (Read 1189 times)
KB1OCC
« on: September 17, 2007, 12:18:53 PM »
I would like to know what kind of 2m/70cm antenna this group would recommend for a sailboat exposed to salt water.  I know that a regular marine antenna comes close in frequency for the 2m band, but the 70cm throws a wrench in it.
Any suggestions?
« Reply #1 on: September 17, 2007, 12:58:26 PM »
I don't know about the other guys, but I use a NMO2/70BK mounted on an angle bracket at the very top of the mast. The marine VHF is about 3 foot lower, directly under the dual bander. Both are fed with RG8X.
Alan, KØBG
www.k0bg.com
W3LK
« Reply #2 on: September 17, 2007, 02:06:19 PM »
Alan's suggestion is excellent.
If you want something with a fiberglass radome, either Diamond's or Comet's shortest antenna will do, although neither will give any actual performance gain over the Larsen.
Lon - W3LK
Naugatuck, Connecticut
KB1OCC
« Reply #3 on: September 20, 2007, 07:26:09 AM »
Thanks for the advice.  I have the Larsen mentioned here on my car and like its performance.
Thanks
Brian
KB1OCC
