Author Topic: 10 meter Antenna Recommendation  (Read 485 times)
KC0AAB
« on: June 25, 2008, 09:09:23 AM »
Greetings,
 Which antenna would be a top performer for a 10 mtr transmitter with 50 watts out?  I would prefer a perm. vs. mag/mount.  I do have a older 10/11mtr. M/M from Rat shack trimmed to 28.400 but as for a permanant mounted ant. what works well ??
73 de kc0aab
K3GM
« Reply #1 on: June 25, 2008, 10:06:53 AM »
I use a Larsen NMO27BCO coil with a stainless steel whip mounted on a permanent NMO mount.  It's short enough to sit on the roof of my Tahoe without banging anything except the lowest of branches.
N8EKT
« Reply #2 on: June 25, 2008, 01:28:03 PM »
Larsen NMO27C coil and whip $25.95 at R&L Electronics
N8EKT
« Reply #3 on: June 25, 2008, 01:35:09 PM »
Mag mounts because of poor capacitive coupling at frequencies below 30mhz should be avoided.
The best performance will occur with a 3/4 inch hole mount NMO in the cener of the roof.
A base loaded 1/4 wave design like the Larsen NMO27C will be fine.
If you intend to trunk mount an antenna, a top loaded
type antenna would be a better choice.
« Reply #4 on: June 26, 2008, 10:07:51 AM »
Stainless steel "CB" whip cut to 98" length, installed in a ball mount high on the fender of the vehicle.
Very strong, secure, weatherproof, good ground, efficient antenna -- impossible to beat with anything other than the same whip mounted in the center of the roof, also using a ball mount.  (I've seen that done, and it's the best performance you can get -- but kind of ugly and crashes into stuff a lot.)
WB2WIK/6
KE5MXA
« Reply #5 on: June 26, 2008, 09:03:34 PM »
I know the arguments about using mag mount antennas. i am running a Wilson 500 mag mount(with short wire running from mag mounting bolt to ground) on my work van while I wait for my screwdriver. Running a Ranger 2950 I had a good qso with Costa Rica from SE Texas. Lately I have had no problems making contacts. Now running a FT-450 still making good contacts.
Just my 2cents
KD4LLA
« Reply #6 on: June 27, 2008, 06:53:18 AM »
I have used a RS HTX-100 and SS cb whip cut for 28.400 bolted to the bed of my pickup truck.
W5WSS
« Reply #7 on: July 08, 2008, 11:49:25 PM »
I use a Hustler ssm-1 ball, mount, spring and a ss 9' whip mounted atop a taurus wagon roof and centered. It is longer(108"+spring) than a 10m quarter wave whip (98") but I use an LDG auto tuner to work the warc bands up to 20m. and need the extra length, in fact when I operate from a hilltop and am stationary mobile for a long time I have used an electricians split bolt to clamp another 48" whip extension near the top. apx.(12'4") this simple technique works out well. Regards W5WSS 73
KX0Z
« Reply #8 on: July 13, 2008, 10:34:48 PM »
I used a  venerable K40 magmount right in the center of the roof. Seem to work well. Worked Alasksa from Kansas on 4 watts with my 148GTL.  Of course when 10m is open, its open..
