Author Topic: fender bracket NMO mount -or- lip mount?  (Read 1194 times)
KE7PMY
« Reply #15 on: November 08, 2007, 07:48:11 PM »
Surprisingly, it doesn't lean that far back.  I haven't gone faster than 60 or 70 yet though.  I'll be driving 700 miles on Sunday.  Remind me to let you know how it went.
W3LK
« Reply #16 on: November 08, 2007, 08:35:20 PM »
<< The whip on the Larsen NMO2/70B seems small and looks like it would lean back at highway speed, How does it hold up at speed?>>
At 70 mph there is less than a couple of inches of lean. The whip is rather large in diameter for its length and there is little wind resistance.
Lon - W3LK
Naugatuck, Connecticut
W3LK
« Reply #17 on: November 08, 2007, 08:40:13 PM »
<< I assume I will need to seal up the bottom of the NMO assembly where the coax attaches.>>
The easiest thing to do is simply spray two or three coats of PlastiDip on the underside.
Lon - W3LK
KE7PMY
« Reply #18 on: November 09, 2007, 09:53:18 AM »
Pictures of the better setup.
http://www.qrz.com/uploads/post-5-30707-IMG_5682_480_360.jpg
http://www.qrz.com/uploads/post-5-30799-IMG_5683_480_360.jpg
K7AAT
« Reply #19 on: November 18, 2007, 09:54:51 AM »
   "Which is preferred? A vehicle specific fender/hood bracket, or a SO-239 trunk lip mount used on the hood as shown in the attached picture? "
    In my opinion,  the  mount that actually 'screws' to metal for support would be electrically better;  however, the Diamond type clamp mounts you point to are pretty physically robust and work well for numerous hams I know.
    But personally,  I prefer the very low profile type lip mount made by Antenex at:
     http://www.antenex.com/index051206.htm
    In either case,  if you are talking VHF/UHF, the Motorola NMO type mount is the superior antenna base to have on whatever type base mount you use.  Good luck.
    Ed   K7AAT
KG6ZJO
« Reply #20 on: August 04, 2008, 11:55:56 PM »
Is there any significant difference between the Larsen NMO2-70BK & the NMO2-70B?
I see that the coax cable is included with the BK model. The BK model is $125 & harder to find for sale.  The nmo2-70B is around $60. Is there any good reason to hunt around for the BK instead of the B plus a nmo connector & some good coax?
Thanks!
