Author Topic: MAXON SM-4150 as 2 meter VHF mobile  (Read 11693 times)
PU2PLL
« on: January 18, 2009, 06:05:55 AM »
Hi all,
I got one MAXON SM-4150 and want to use it as a mobile two meter radio . Is it possible?
Fernando - PU2PLL - BRAZIL
« Reply #1 on: January 18, 2009, 08:36:48 AM »
You can't with out modifying the radio. The lowest you can program the radio is 151.000 MHz. It has been done, but requires a lot of work. What's more, it's only 12 channels. For the same money one of these costs used, you can buy a decent 2 meter amateur transceiver with a lot of bells and whistles, and ALL the 2 meter frequencies.
Alan, KØBG
www.k0bg.com
N2HBX
« Reply #2 on: January 18, 2009, 06:30:25 PM »
I had a GE Monogram (which was a 4150-EX labelled for General Electric) that was 16 channels and worked just fine in the 2 meter band. Had to retune the front end a little to peak the sensitivity, but that was it.
Larry, N2HBX
AA4TX
« Reply #3 on: January 20, 2009, 09:29:45 AM »
It depends on the band-split that you have.
The M model (M: 153 193 331I, 150-165MHZ) will do 2 meter just fine, (I have four of them in 2 meter service). But as already posted, an RX alignment may be necessary for best sensitivity.
The H model (H: 153 193 492I, 160-174 MHZ) will not do 2 meter without modification.
Hope this helps!
John
KI4LTX
WB5OXQ
« Reply #4 on: May 12, 2012, 12:46:22 PM »
I just aquired 5 of these as trade ins because commercial users cannot use these after feb 2013.  My software will program these down to 144mhz and I have tried 5 and all but 1 worked.  I have not checked rx sensitivity but all made at least the rated 40 watts out.  wb5oxq
