Author Topic: Detuning effect of trees in a mobile installation  (Read 1111 times)
VK2JAF
« on: February 01, 2009, 02:05:12 AM »
Hello from Down under,
Just playing with mobile installation, and am noticing the effect of low hanging trees affecting "tunability" of mobile antennas for mobile installations..
Icom 7000..various commercial antennas..if in open can tune OK, however if sitting under low hanging trees..difficulty encountered..
be interested in any information on this topic,
regards,
Derek VK2JAF
« Reply #1 on: February 01, 2009, 05:56:09 AM »
This happens to EVERY antenna, it's more noticeable in mobile antennas because they are mobile.
Probably the largest effect is caused by driveways that are steel reenforced. Most neophyte operators don't think about the metal under their feet so to speak, and they tune up the antenna perfectly. They pull out into the street, and now the SWR is too high.
Both of these are caused by capacitance, albeit the effects are actually on opposite ends of the antenna. The trees effect the capacitance at the top end, and the steel in the driveway on the lower end, of ground loss if you please. Ground loss, incidentally, is the largest factor a mobile operator has to contend with.
Alan,KØBG
www.k0bg.com
