Author Topic: TS-690SAT problems with display  (Read 5109 times)
GRANDC
« on: November 18, 2000, 06:00:08 AM »
Hi All,
I have some problems with the display of my TS-690SAT:
a) The first digit of the “memory channel” is always like a “8” without the vertical segment bottom right, but wen I use the channel from 80 to 89 the display appear correct.
b) Are always turn on the letter “L” and “B” of the LSB Mode and “SB” of USM Mode, when I use the USB or LSB mode the display is completed
c) Are always turn on the last two leds of the SWR bar.
d) Are always turn on the letter “WR” of SWR, but when I use the SWR bar the display is correct.
The problems are only on the display or driver, all the function involved work well.
I tried to reset with power-on + (A=B)  and  (A/B) without effect, the battery is ok and I have not the “service manual”.
I appreciate any comment, thanks in advance for your time,
regards
Cesare
