Author Topic: VX-1R  (Read 2484 times)
Guest
« on: May 18, 2001, 10:02:14 PM »
VX-1R on 2 meters jumps to PS (programmed scan) and the display shows 3F3F3F in memory mode.  Works ok on VFO but when I go back to memory mode it will scan for a while and then lock up the screen and sometimes I have to remove battery to get it turned off.  Have done hard reset twice with no luck. Will I have to send it in or can it be reset in field?  Seems to be ok on other bands. I was using with a mag mount ant. with TSHWR in area.  Thanks for you help.
