Author Topic: ICOM HM-103 Repair  (Read 5412 times)
AC7KZ
« on: June 27, 2003, 11:08:14 PM »
I am replacing the 8 pin modular plug on the Icom HM-103 Microphone.  I cut the old plug off, and lo and behold there are more wires. Can someone tell me the order of the wires, and which ones to use.
There were 2 black wires in the plug, when I cut the plug off, there is a red wire, copper wire, and silver wire, along with the blue, green and white.
thanks for the help,
73's
VK2ACM
« Reply #1 on: June 30, 2003, 08:06:04 AM »
not sure if this site can help you,it will show you the schematic diagram for the hm103 mic,you should be able to figure it out from there,it is in a pdf format...73 clint
http://www.rigpix.com/icom/ic706mkiig_manual.pdf
