Author Topic: Re-wire a MC-50 4-pin mic to fit a 8-pin Kenwood  (Read 5582 times)
KI4CMO
« on: January 28, 2007, 04:46:19 PM »
I have a mc-50 mic I would like to rewire to fit my kenwood 850S, the mc-50 is a 4 pin plug and the 850 is a 8-pin plug.. Anyone have the pin asignments
thanks
please email me at ki4cmo@yahoo.com if you have the pin assignments
thansks
Jeff
ki4cmo
KE4DRN
« Reply #1 on: January 28, 2007, 05:27:16 PM »
hi jeff,
you can d/l the mic manuals here
wiring info in the instructions.
http://n6wk.com/kenwood/
73 james
WA9SVD
« Reply #2 on: February 01, 2007, 01:18:32 PM »
Kenwood has the pin assignments available on their web site.  (www.kenwood.net.)  They give the pinouts for mics, and many of their accessory cables/plugs.
    The "Standard" Kenwood 8-Pin assignment:
1  Mic audio
2  PTT hot line
3  DOWN button (not applicable in your case)
4  UP Button     -- ditto --
5  8 Volts, limited to 8 mA max draw
6  No connection; sometimes connected to receiver audio out in some radios.  (Easy for Packet TNC connections!)
7  Mic (audio) shield/ground
8  PTT ground.
    So you would use Pins 1,and 7 for mic audio, and 2 and 8 for the PTT switch on the MC-50.
    Not sure how the original MC-50 4 pin was wired, but that shouldn't be too difficult to figure out, or get from the Kenwood site.
Good luck!
P.S.  If sent by e-mail, the info might help you.  Posted here, with the question, it may help others also.
G3XHP
« Reply #3 on: February 11, 2007, 04:21:25 AM »
I have a friend who has recently gone blind and wants to use a hand mic. instead of a desk mic., for obvious reasons, on his Kenwood TS530. The problem in doing this is that, the MC-35S 50K  4 Pin Mic. is no longer available.
Looking at the possibility of using one of the more recent mics via a matching transformer. Can anyone help with information or, dare I ask, have an old MC-35S Mic "kicking around"?
Geoff. g3xhp
