Author Topic: Mod questions  (Read 2429 times)
2ST123
« on: February 09, 2007, 08:52:02 AM »
We are just getting into ham radio and leaving regular c.b. . I know modifications are illegal for c.b. , but what kind of mods can you legally do for ham radios as a technician class ? Can you make channel expantion modifications? Power modifications? and other mods?
My wife did a little work on generators in the military, Maby she can learn modifications.. Thanks
                              Roy
K8AC
« Reply #1 on: February 09, 2007, 10:13:01 AM »
Roy:  You may do any modifications that you're capable of doing, regardless of license class.  Of course, the results of your modifications should be respectful of the frequency assignments and power limitations.   The ham bands are not subdivided into "channels", although you'll find fixed frequency operation on the bands where there is repeater operation (2 meters, 440, etc.).
One of the differences you'll find in Ham radio compared to CB is that the vast majority of hams follow the regulations pertaining to power output and assigned frequencies.
Modern ham gear usually has all the bells and whistles that one could want and modifications are usually limited to installing filters.  Those who participate in MARS have a need to be able to operate on specific frequencies just outside of the some of the amateur bands and modifications are often available to effect such operation.  Unless you have plans for MARS operation, modifications to allow you to operate outside of the amateur bands could lead to more trouble than you want!
K8GU
« Reply #2 on: February 09, 2007, 10:23:19 AM »
It's technically legal to make whatever modifications you wish.  However, the modification may make it illegal to operate the radio.  For instance, few, if any, amateur transceivers are type-accepted for use in services outside the amateur bands, EVEN IF YOU ARE LICENSED FOR THEM.
There are a few legitimate modifications that actually improve the performance of radios with little or no detriment to the proper operation.  (Two examples are W8JI's noise blanker and key click modifications to the FT-1000* radios.) But, this is generally the exception...
WA9SVD
« Reply #3 on: February 09, 2007, 05:16:37 PM »
It's not a maytter of "MAY."
    NO current (or past) AMATEUR equipmenthas ever been certified for operation outside the Amateur frequency allocations, nor is any likely in the forseeable future.
    Any radio may be modified for use on the Amateur bands, be it commercial, or CB equipment.  But once modified in any way that affects the transmit chain, (either RF or audio) that radio can no longer be used in it's original service; it's no longer certified.
    In addition, any equipment modified by an Amateur still has to meet the FCC standards for spectral purity.
    It IS possible that some commercial equipment can be PROGRAMMED to operate on some Amateur frequencies, as well as the original commercial frequencies.  THAT would be perfectly legal, and would normally preserve the certification for use in the original service.
W3LK
« Reply #4 on: February 09, 2007, 06:38:55 PM »
I get concerned when folks who do not yet have an amateur radio license start asking question about modifying equipment, especially when they start talking about frequency expansions.
Other than Military Affiliate Radio System (which requires a separate license issued by one of the three MARS services) there is no legal reason to modify the frequency range of amateur radios.
Lon - W3LK
Baltimore, Maryland
KB5DPE
« Reply #5 on: February 11, 2007, 06:48:03 PM »
"Other than Military Affiliate Radio System (which requires a separate license issued by one of the three MARS services) there is no legal reason to modify the frequency range of amateur radios"
I can think of one.  There are some earlier radios that meet stability and other requirements that can be modified to operate on the 60M band.  My FT-990 with TCXO is one example.  I agree, however, that caution is in order.  You also need a suitable frequency standard to assure that that TCXO is properly set and a spectrum analyzer wouldn't hurt to assure spectral purity as well.  You wouldn't rebuild a race car engine without a properly equipped machine shop available; similarly, you can't modify a ham transmitter without the proper test equipment to assure the results.
W3LK
« Reply #6 on: February 12, 2007, 07:00:27 AM »
<< I can think of one. There are some earlier radios that meet stability and other requirements that can be modified to operate on the 60M band.>>
That is not operation outside the amateur bands.
Lon W3LK
Baltimore, Maryland
KE4DRN
« Reply #7 on: February 12, 2007, 05:15:52 PM »
hi roy,
take a look at this link, it shows frequencies available based on license class and
the power levels allowed.
http://www.arrl.org/FandES/field/regulations/allocate.html
plenty of room to explore many different types of
communications, cw (morse code), ssb, fm and am voice, digital modes etc.
take a look here to find a local radio club in your area,
many welcome those interested in getting their license and offer classes to help.
http://www.arrl.org/FandES/field/club/clubsearch.phtml
73 james ke4drn
KE5FRF
« Reply #8 on: February 24, 2007, 08:49:25 PM »
//We are just getting into ham radio and leaving regular c.b.//
Doesn't this statement trouble anyone else?
How do you leave "regular CB"? IS there another kind of CB that you wouldn't be leaving when you leave the regular one?
Oh, I know, you're leaving regular CB but not freeband CB, and you want to get a ham license to learn how to trick out a ham radio to make it go where you want.
I see now.
Gawd.
W9GB
« Reply #9 on: February 26, 2007, 08:31:23 AM »
Roy -
The FCC rules and regulations are codified in Title 47 of the Code of Federal Regulations (CFR). They are initially published in the Federal Register.
The FCC does not maintain a database of its rules nor does it print or stock copies of the rules and regulations. That task is performed by the Government Printing Office (GPO).
Code of Federal Regulations - Title 47 [Telecommunications]
http://wireless.fcc.gov/rules.html
Part 95 - Personal Radio Service
Citizens Band is one of the services covered under these rules and regulations.
http://www.access.gpo.gov/nara/cfr/waisidx_06/47cfr95_06.html
Part 97 - Amateur Radio Service
http://www.access.gpo.gov/nara/cfr/waisidx_06/47cfr97_06.html
w9gb
