Author Topic: icom 746 meter weird problem  (Read 236 times)
KE7EOZ
« on: February 26, 2007, 09:08:24 PM »
I have an icom746 and its being having a little proble the meter does not reach the full scale on power , hoever theradio power is ok cheked it out with a external meter, the meter just reach to +40 but does not go all the way to +60 or 100% in power , send it to ciom twice and got back the same way and they said it works jsut fine for them so no idea if anybody had similar problem before.
WW5AA
« Reply #1 on: February 27, 2007, 02:24:04 PM »
Sounds like the 746 may be cutting back on power to protect itself from high SWR. My 746 starts to cut back at 1:1.5. You may want to check your SWR with a very good SWR meter.
73, de Lindy
KE7EOZ
« Reply #2 on: February 28, 2007, 04:17:44 PM »
SWR are fine so that is rull out, ths happends in all bands
W3LK
« Reply #3 on: February 28, 2007, 07:13:32 PM »
What mode are you doing this in? It must be a constant carrier mode such as CW (with the key down) or FM.
Trying to check power output on SSB requires a peak-reading SWR/Power meter.
Lon - W3LK
Baltimore, Maryland
