Author Topic: ICOM 740---  (Read 165 times)
VE3GNU
« on: April 14, 2008, 01:36:19 PM »
Having owned the 740 since 1982, and other than a 'wonky' compressor switch, and recently the loss of the meter light---the rig has been flawless.  Mind you, it has never seen 'heavy-duty' service over the years---mainly used for SSB and some PSK-31.
What is obvious, however, is the efficiency---only at 60% of full output.  I understand that the caps of rigs of this vintage should really need to be replaced.
It is no longer my main rig as I'm using the Argonaut V for the past 2 years, and mainly for CW.
My question:  Is it worthwhile to repair a 25-year old rig OR sell it and have someone else look after the 'upgrades'---while the rig is still in sound operating condition?
Thanks in advance for any and all suggestions.
VE3GNU
« Reply #1 on: April 16, 2008, 03:08:31 PM »
What do you mean by "efficiency?"
"Efficiency" would be a measure of RF output vs. DC input, with DC input being Vcc*Ic.  If your Vcc is 13V and Ic is 15A (DC input 195W), your output should be about half that, or 97W.
What do you mean by "60% of full output?"
VE3GNU
« Reply #2 on: April 16, 2008, 04:25:53 PM »
WB2WIK---Thanks for the reply, and apologies on the 'efficiency' comment---an assessment made via a 'tuner' and my G5RV when, what I perceived to be a matter of 'efficiency'---and the full output measured only at 60 watts.
Another 'look' took me to my resonant 20 meter wire and gave me the expected 80 watts out---i.e. 'full marks'---
Aside from that, what are your suggestions as to 'what to do' or 'possibly consider'?
Many thanks for your input, and 'steering me' in another direction---
VE3GNU
K8WV
« Reply #3 on: June 05, 2008, 03:08:10 PM »
The Icom 740 is, still today, an excellent rig -- especially with a Heil microphone through a Behringer 802 mixer/preamp/eq.  (And you can then forget the darned compressor!)  You don't need a iC Heil Element.  Any of their dynamic elements will work fine.
Repairs are readily, and reasonable available through MTS - Malcomb Technical Services.
With the proper filters the 740 holds its own with anything.
