Author Topic: Icom IC-2100 CTCSS Tone Problem ?  (Read 2799 times)
ROBBIE
« on: April 07, 2005, 10:13:02 PM »
I have a buddy who has been using his Icom IC-2100H as a base station for about 5 years now. He recently noticed that it will recieve and decode CTCSS tones properly, but will not transmit or encode CTCSS tones. I went through and checked his settings, as he is an older friend, and doesn't have the eyesight to do it anymore. Everything appeared to be correct. The radio is set to encode and decode a CTCSS tone. I checked his transmissions with a CTCSS decoder, and the rig just isn't transmitting one. Other than that, the radio works flawlessly. He has pretty much decided to go ahead and purchase a replacement for it, but has anyone every had this happen ? If so, how was it corrected, if it was corrected ? Thank you in advance.
« Reply #1 on: April 08, 2005, 06:22:40 AM »
First thing I would try is a master reset.  Got nothing to lose:
Turn unit OFF
Hold the [SET] and [S.MW] buttons
Turn unit ON
CLEAR appears on the display
ROBBIE
« Reply #2 on: April 08, 2005, 02:47:42 PM »
Did the Hard Reset, Reprogrammed for a new CTCss tone, still nothing. I emailed Icom Support. The only help they could offer is for me to send it to them. With the cost of shipping it to them and the cost of them fixing it, one can purchase a new one just as easy. I would like to get this one back into running order though. Thanks
WQCF778
KD6AAJ
« Reply #3 on: December 11, 2008, 10:44:52 PM »
Did you ever fix it? Or find the problem?
I have an IC-2100H and I want to increase the ctcss tone decoder sensitivity, so I'm studying the schematics for it. My friends IC-2100H also has weak decode.
Ed, KD6AAJ
http://solasprime.com
