Author Topic: TM-731a Battery question.  (Read 996 times)
W6TGE
« on: May 16, 2009, 02:10:19 PM »
Well, my battery is dead. Is the replacement just a CR-2032 3V Lithium battery? I know there are tabs, but Batteries Plus will spot weld them wherever they are needed for $1. Also, is the plus on top or on the bottom. Mine is dead after 19 years...imagine that!
TIA,
Dave
KA5IPF
« Reply #1 on: May 16, 2009, 04:38:56 PM »
Mine have the plus on the PCB side, top or bottom Huh?
W6TGE
« Reply #2 on: May 16, 2009, 05:45:12 PM »
The PCB side would be Bottom. When I open the rig and pull down the front panel, I see the battery from the top. Is that the - side? It does not look like there is any special trick to unsoldering it. Also, I can call Kenwood to see what they charge, but if it is just a CR2032, Batteries Plus will sell you one with tabs welded on to match the original for only $1 more. I want to see what Kenwood wants for this...if they are not already old from Kenwood.  :-) At least Batteries Plus has all of them without tabs so they move a lot of stock.
