Author Topic: AEA Isoloop 10/30 repair  (Read 3904 times)
KC8GPD
« on: July 30, 2009, 07:52:18 AM »
are there any parts available to repair these.
the big plastic gear for the air variable cap is trashed.
has anyone done a home brew solution to this problem?
also has anyone home brewed a stepper motor controller for these?
mine has no controller either. i hate to just see it have to be trashed.
N3OX
« Reply #1 on: July 30, 2009, 03:52:15 PM »
Oh definitely don't trash it.
I haven't built a stepper controller for my magloop yet but I probably will at some point.  Right now I just use a simple DC motor drive with limit switches:
http://n3ox.net/files/magloopnew_lg.jpg
It's pretty easy to use band noise to get the tuning "about right" this way.
If you want to get started building a stepper controller with "memorized" or "commanded" capacitor positions, you can look at what I did build a stepper controller for:
http://n3ox.net/projects/stepperswitch/
What you need is probably closer to another project I built, this one for the lab.  It's a little "antenna rotator" designed to point an ultrasound transducer for flow measurements in different directions:
http://n3ox.net/files/US_rotator.jpg
This uses a normal four coil unipolar stepper and a (really expensive) worm gear drive.  The controller is also an Arduino with exactly the same MOSFET circuits as my other switch.
rotator is available here:
http://n3ox.net/files/US_rotator_v_1_3.pde
This one is probably more up the alley of a variable capacitor drive.  It has a serial interface that can be accessed using Hyperterminal and accepts inputs in the form of 0-290 degrees in 1 degree steps (could be much smaller actually) and moves the switch accordingly.  It uses a 35:1 worm gear reduction ... but I had to machine the housing for it, so it's not a very good home project.  But spur gears are a bit easier to use (you'll see that careful drilling was good enough on my antenna switch to engage those gears sufficiently).
So those might be some starting points for a controller for your loop.  If you want it to tune to low SWR, that can be done too but is harder.  I've seen at least one full-autotune ham loop homebrew project but can't find it right now.
Gears are available from places like Small Parts:
http://www.smallparts.com
and Stock Drive Products
https://sdp-si.com/eStore/
And probably more.   You'll have to do some research to figure out the right pitch and size to get a drop in replacement but acetal ones are pretty cheap.
I've had good luck using Lego for medium torque loads, too.
Dan
Dan
http://www.n3ox.net
N3OX
« Reply #2 on: July 30, 2009, 03:52:58 PM »
whoops, shoulda been "code is available here" in front of the .pde file ;-)
Dan
http://www.n3ox.net
WA3MJY
« Reply #3 on: August 02, 2009, 05:16:53 PM »
I had the similar problem a couple of years ago. My antenna stopped working and when I opend it up to look inside I found that the plastic gear was broken.  My solution was to glue the pieces together with JB Weld. I then carefully dressed up the gear teeth with a small file. The antenna works perfectly now.
