Author Topic: vol/sq pot for TR-751  (Read 3846 times)
G7TOK
« on: March 08, 2009, 08:42:46 AM »
Hi,
Does anybody have a clue where I can source a replacement dual-concentric volume/squelch potentiometer for my Kenwood TR-751E ?
Many thanks in advance,
Gary - G7TOK
g7tok@hotmail.com
G7TOK
« Reply #1 on: March 08, 2009, 08:56:07 AM »
I think the part number is R23-9402-05
G7TOK
« Reply #2 on: March 18, 2009, 05:25:03 PM »
Anybody ?
W3LK
« Reply #3 on: March 18, 2009, 07:41:33 PM »
Kenwoodparts.com
Discont.    R23-9402-05     (L10) POT VOL & SQUELCH (10K, 50KB) TR-751A          $19.53
Took two minutes on Google. Smiley
Lon - W3LK
Naugatuck, Connecticut
KE4DRN
« Reply #4 on: March 19, 2009, 04:42:16 PM »
Hi Gary,
that kenwood part is no longer available.
I replaced a similar pot/switch on an
old scanner with one made by Alps.
take a look, you may find one that will work for
the kenwood.
http://www3.alps.com/WebObjects/catalog.woa/E/HTML/Potentiometer/MetalShaft/RK097/RK09711110AL.html
if you ask, they will send you a sample.
73 james
W3LK
« Reply #5 on: March 20, 2009, 07:45:44 AM »
My apology for the mis-information.
I did not realize the "discont" meant they no longer carried it, just that it was out of production.
James, if that means it's no longer available, why does Kenwood parts list a price? That seems contradictive.
Lon - W3LK
KE4DRN
« Reply #6 on: March 20, 2009, 06:35:59 PM »
hi Lon,
kenwoodparts.com is not connected with kenwood,
they are East Coast Transistor located
on long island ny  (not far from CT)
I guess their website and order system
could use an update/refresh !
pacparts.com shows is discontinued.
I even checked rossdist.com, no luck.
I'm sure Alps has a part that will work.
73 james
W3LK
« Reply #7 on: March 21, 2009, 06:39:42 AM »
James:
<< kenwoodparts.com is not connected with kenwood, >>
I am aware of that - now. Smiley
I guess they are the radio equivalent of Numrich Arms for "obsolete" gun parts.
Have a good weekend.
Lon - W3LK
G7TOK
« Reply #8 on: March 21, 2009, 01:50:45 PM »
Thanks everybody, but no joy so far.
The problem with this particular part is the built in power switch.
I've seen several similar pot's but none with the switch.
I'll have to hold out and see if I can source an original.
Many thanks.
G7TOK
« Reply #9 on: April 06, 2009, 02:51:34 AM »
Is anybody aware of a compatible part from another Kenwood set or otherwise ?
KE4DRN
« Reply #10 on: April 07, 2009, 04:01:41 PM »
hi Gary,
is the switch worn out or the pot(s) ?
73 james
G7TOK
« Reply #11 on: April 08, 2009, 12:30:08 AM »
Hi James,
The switch and the squelch pot seem fine, just the volume section has failed.
Regards,
Gary.
KE4DRN
« Reply #12 on: April 08, 2009, 06:19:38 PM »
hi Gary,
you may be able to drill a small hole in the
plastic and force in some contact cleaner,
that may help until you can find a replacement.
73 james
G7TOK
« Reply #13 on: April 19, 2009, 01:20:23 PM »
Thanks James,
I may try that in desperation !!!
Well, a U.K. Kenwood repair center have stated that they have several in stock.
They will not sell me the part.
They will however, gladly charge me $60 for the part and nearly $200 for the labour.
K4TLJ
« Reply #14 on: April 19, 2009, 09:12:23 PM »
Try contacting http://www.oldradioparts.net/
Mark has a very extensive stock of pots and there is a good chance that he can assemble a control that meets the specs.
