Author Topic: qrp dummy antenna  (Read 5258 times)
N5JYW
« on: July 28, 2001, 10:05:58 AM »
I am building an SST transceiver. The instructions call for the use of a dummy antenna. I am interested in building sometthing simple, but effective, for this project only, The antenna connection is BNC. Any specifics? TNX--Bob
KA1DBE
« Reply #1 on: July 28, 2001, 03:33:06 PM »
I posted you in the homebrew section but to go further, take the two resistors and solder one lead to the center of a chassis mount BNC connector and solder the two remaining leads to the ground side.  Makes for a very small and compact dummy antenna.  73's and good luck!
KA3UEH
« Reply #2 on: August 02, 2001, 07:49:45 AM »
If you use the MP-1 with the tripod, it makes for a good dummy antenna, too. (hi hi)
