Author Topic: No output power in am/cw/ssb on the FT-817  (Read 4359 times)
ON4SSC
« on: December 09, 2003, 08:33:16 AM »
Hello all,
Yesterday we did some tests with a friend of mine. I took my 817 at
his home, connected the rig to a yaesu antenna tuner, connected
itself to a long wire. The swr was not notch. In FM the output power
readout on the tuner was almost 5 watt when transmitting. However in
usb, lsb or am there was no power output when modulating (test done
on the 20m band, and also on the 2m as well) ! The mic gain was set
to the maximum. Another ham received me in fm but he heard nothing in
usb. What's strange is that the One Touch Tune produces a 5w carrier.
Is there a menu somewhere which has to be changed to allow more power
in these modes ? Are my finals dead (don't think so because it's
working in fm). Do I have to enter the "secret menu" and change
something ?
Thanks for your help,
ON4SSC
Stephane
ON4MGY
« Reply #1 on: December 14, 2003, 03:04:28 PM »
Hi Stephane,
I would suggest you just do a complete micro-pocessor reset. If there's any setting wrong, when going back to the factory-defaults you're setting will be OK again. If that doesn't work I'm afraid you'll have a problem in which I can't help.
73 and good luck
ON4MGY Nicolas
ON4SSC
« Reply #2 on: December 14, 2003, 07:54:36 PM »
I did a complete reset, but it didn't help ... I've sent my FT-817 for repair. A ham gave me (temporary) his FT-817 until mine is repaired.
Thanks anyway for your answer.
ON4SSC
Stephane
LNXAUTHOR
« Reply #3 on: December 14, 2003, 09:56:55 PM »
- interesting problem, as there is only one 'finals' board in the 817 (i have a spare in shrink-wrap as a backup in case anything ever goes wrong with my unit)...
- sounds like a factory alignment problem (Yaesu appears to use computer-hosted calibration on its rigs, and each rig will have different settings)...
ON4SSC
« Reply #4 on: February 01, 2004, 11:16:24 AM »
The technician at the shop where I bought it found the problem : the IF filter had failed ! He didn't know how this could happen but it happened anyway.
73' de ON4SSC
Stephane
