Author Topic: Skype background noise canceller?  (Read 32035 times)
N3OX
« on: April 26, 2009, 05:10:33 PM »
I'm playing around with remoting my station using Ham Radio Deluxe for the rig control and Skype for the audio.
Skype version is 4.0.0.226... current as of 4/27/09.
It works OK except that the background noise cancellation works to get rid of the background static, which, believe it or not, I do not want (fond of listening to weak signals in the noise and I'm pretty sure Skype won't manage to differentiate between pure noise and weak sigs)
Anyone come across and fix this problem?  There doesn't seem to be an option and don't seem to be any config files.
Maybe Skype is no longer the appropriate software solution for rig audio?
Dan
Dan
http://www.n3ox.net
WB2LCW
« Reply #1 on: June 03, 2009, 01:08:03 PM »
I have seen posts about a program called IPsound that some people have tried! Google for it !It may solve your problem.
mike
N3OX
« Reply #2 on: July 14, 2009, 09:25:55 AM »
Yeah, I think that's the plan eventually.  Skype is set up to get through firewalls very easily, but I'll just set up a VPN probably, and should be good.
I've got VPN software on all my computers anyway, so that I can access my lab computers from home.
Dan
Dan
http://www.n3ox.net
N0YE
« Reply #3 on: July 15, 2009, 06:27:28 PM »
The BARC club remote radio activity has had K0RZ and his remote station development as a mentor. One Thing Bill has found is that Skype version 2.5 sounds better for remote radio work than more current Skype versions.
You can get back issues of Skype from http://www.oldapps.com/skype.php
Give it a try and let us know if you find the older version serves you purposes better.
Don, N0YE
KA9CQL
« Reply #4 on: September 10, 2009, 12:48:27 AM »
Greetings.
In the VoIP (Voice Over Internet Protocol) world, the setting you are talking about is sometimes called "comfort noise", sometimes called "silence suppression".
Most VoIP clients (Skype is a VoIP client) have some settings that allow the substitution of silence (or near-silence) to save bandwidth.  Look for the keywords mentioned above, and you may find the settings you are looking for.
'73
- Mike S.
  KA9CQL
  Victorville, CA, USA
K5DN
« Reply #5 on: December 10, 2009, 02:47:50 PM »
I have been experimenting with skype and have had no luck getting acceptable sound quality with CW.  Voice signals sound good.  I have tried the newest version as well as one of the 2.5xx versions.  The older one has a config file that can be edited to turn off agc and echo cancellation, but it does not seem to help.  Has anyone else solved this problem?
I also have IPsound running also, but am having trouble with serious pops and clicks.  A separate thread may be in order for this.
KE4ZHN
« Reply #6 on: December 19, 2009, 02:50:36 PM »
Skype uses an automatic gain control on the microphone. Its a simple matter to disable this feature and set the gain at a fixed level. Check the tools, options menu under audio settings.
